Handbrake, Rear Shoes needed.
				bmt
Replaced pads all round today and found that a rear knocking noise was a Anti roll bar clamp broken so replaced that aswell.
Still have no Handbrake and upon further inspection I see they have no meat left on them so peplacements are needed any ideas where from and how much?
None in the shop for sale.
Thanks Dave
Thanks Dave
				Ralph
- dandywarhol
				David Edwards
I still to this day travel a sizeable distance with the handbrake still half ondandywarhol wrote: Don't understand why they're worn out when it's a parking brake - unless it's being used for handbrake turns
I only display this trait with the bongo strangely...
				Veg_Ian
I'm inclined to agree but note that the linings on mine are pretty thin and I've marked it for attention for my next service. I'm hoping my local factors still offer a relining service as I don't fancy paying the silly amounts quoted on here.Don't understand why they're worn out when it's a parking brake - unless it's being used for handbrake turns
				bmt
OK now done and what a nightmare.
Had the old ones relined and the discs would not go back on (lining far to thick)
Spent hours grinding them down, swearing and throwing things around my workshop.
Ended up buying new rear discs and shoes, and they have very little lining on them from new.
Anyway put them on and got my MOT and now much calmer and happier.
I also replaced a broken rear anti roll bar bracket and worn front droplinks and wow what a nice ride and big differance, cheap aswell.
So if you have the occasional knock from underneath it might not be as bad as you think it took about an hour to change them over, just a shame the rear shoes were not so easy!!!!!!
				bmt
				bmt
I will say this, when you remove the drum/disc and look at the shoes there are the 2 springs top and bottom connecting both shoes and a smaller spring just above the bottom one.
In my case this had been put on the wrong side causing the shoes to not sit in the centre and cause excesive wear to the leading shoe and inner drum.
It will fit either side but worth making sure they are central before refitting the disc and caliper.
				Veg_Ian
Interesting you say the linings are thinner than usual BMT. If that's the case then maybe mine have a lot more life in them than I originally thought. I suppose it's too late to ask now but it would be worth knowing the thickness of the lining from new so that it's possible to work out exactly by how much mine have worn.
