bleepeing indicator
woodsky3
bleepeing indicator
Post by woodsky3 » Wed Aug 29, 2007 3:41 pm
when i indicate right, my bleeper is going off, though inly in the vicinity of the rear light cluster, not at the dash. indicator works fine, although rear fog (dangly) has packed up. any suggestions of where to look and what to look for before i go blindly fumbling round?
Post by bigdaddycain » Wed Aug 29, 2007 3:48 pm
Hi woodsky, when you say bleeper, i assume you mean the click that comes from the relay when the indicators are on?
I have a click not a bleep, i cant really tell where the click comes from, as far as i know, the actual relay clicks.
Check the bulb for the rear fog,then the connections at the light (foglight) then the switch last,(its possible for them to vibrate loose sometimes)
P.S. i keep finding i'm bobbing my head to your avatar, till i scroll it out of sight....bob....bob....bob :lol:
Bumbly1
Re: bleepeing indicator
Post by Bumbly1 » Wed Aug 29, 2007 4:30 pm
woodsky3 wrote:when i indicate right, my bleeper is going off, though inly in the vicinity of the rear light cluster, not at the dash. indicator works fine, although rear fog (dangly) has packed up. any suggestions of where to look and what to look for before i go blindly fumbling round?
Is it a retro fit trailer bleeper? Bleep and ye shall find :oops:
daveblueozzie
Post by daveblueozzie » Wed Aug 29, 2007 9:07 pm
do you have a tow bar if so then its the tow bar bleeper informing you of a bulb fault normally on your trailer.
Lost without my Bongo.
