Drivers door rattle....
deeps
Post by deeps » Sun Aug 12, 2007 3:39 pm
I have exactly the same problem as Simon Jones back on 2005...
I found his post with a search but it is now locked and had no replies.. doh!
I have taken the door panel off and think I have narrowed it down to a rod with a white plastic fixing near the lock. I can't see anything out of place, broken, or loose. Please help it's driving (gettit..) me loopy.
Seems to occur when the van goes over a bump which makes it wobble slightly from side to side.
QUOTE :
Posted: Sat Oct 08, 2005 8:55 pm Post subject: Annoying rattle near drivers door
I was hoping someone may have some suggestions on a mysterious rattle/click/clunk that seems to come from just behind the drivers front door. I have so far removed the door card & the panel that covers the seatbelt recoil unit, but been unable to find anything obviously loose. I'm beginning to wonder if it is the door itself moving & making a clunk from the locking mechanism.
Bongopatrol
Post by Bongopatrol » Sun Aug 12, 2007 7:11 pm
Hi Deeps I had a similar noise it turned out to be the door itself if you take the door card or you will see that the door skin is bonded to a strengthening bar down the center of the door the bonding had gave way and the noise was the door skin rattling against the strengthening bar.
Hope this helps.
deeps
Post by deeps » Mon Aug 13, 2007 6:12 am
Bongopatrol,
I saw the bonding you mention, kind of a white glue, nothing seemed loose but I will remove the card again and check more closely.
It's good to have a lead in any case, thx.
dandywarhol
Post by dandywarhol » Mon Aug 13, 2007 3:45 pm
I'd the same problem and used expanding foam - worked a treat :)
deeps
Post by deeps » Mon Aug 13, 2007 7:57 pm
good idea - will definitely use the foam if I find the panel has come loose, we be 5gall drums of the 2 parts of the foam at work and mix it together so I don't think I'll be short :wink:
