Black smoke and lose of power???????? Stinky!!!!
Whilst in the not so sunny Lake District last week my Bongo became poorly. So I would appreciate a little help with her illness..... She had been running so so so well all week, but this morning I started her up fine and drove her about 200m where I parked for around 15mins. Once again she started perfectly but as I drove up the lane 500m or so I noticed Black smoke bellowing from her rear then she lost excelleration (Ziltch) Being such a caring owner I pulled over and called the AA. After the Mechanic had checked her over he diagnosed, that the fuel pump was not working(most probably) and the strong black smoke was diesel. If this is the case where can I buy another fuel pump from and has anyone details of how to change it?
PS: If you saw a White Grey Bongo being relayed From Wasdale to Lee-on-the -Solent it was me.
- westonwarrior
Are you sure its the pump as they are normally very reliable things. Before looking for another pump I'd consider other options. I'm sure that these symptoms could be put down to a malfunctioning EGR valve. Someone else who has more knowledge of the problem may chip in and I think its a relatively easy fix.
1995 N reg 2WD AFT in green/grey
www.whiteroseancestry.co.uk
Where and what is the EGR valve.
Also the AA chappie said it wasn't the Turbo he was quite positive. He also said the Black smoke was a good sign of too much diesel being injected.
Black Smoke.
Check your glow plugs, glow plug relay, fuse to glow plugs.
Hope this helps.
PS Were you burning veggy oil?
Hope this helps.
Saw,
Look at this link for info on exhaust gas recirculation. Similar symptoms to yours.
http://www.igmaynard.co.uk/bongo/forum/ ... e6d37bf7a2
Also this one. Its a long thread but the fault is traced to the EGR at the end.
http://www.igmaynard.co.uk/bongo/forum/ ... hlight=egr
Lots more on the site re the egr system if you just put 'egr' into the search section.
Best of luck.
Best of luck.
EGR recirculates a small amount of exhaust gas when the engine is warm under partial load, light throttle, to improve the emissions. It does not operate at high load. There will be no visible difference to the smoke level, it affects only the composition of the gases. From what you describe I doubt it's the EGR. Black smoke is unburnt fuel which means too much fuel is being injected or there is an air restriction such that there is an excess of fuel. So it could be an air inlet restriction, pump timing or quite commonly can be one or more bad injectors. You could try a dose of injector cleaner first. If still no good I would seek out a diesel specialist who can check out the injectors and pump.
Thanks folks. As suggested I have contacted a Diesel specialist and my beloved Bongo is to be transfered to their garage for further checks. I shall let you know the out come.. just hope they have worked on these beauties before!
"R" White over Grey Bongo Bird.
Just a thought Saw, if your bongo has the winter pack (twin batteries) you probably have a switch on the dash with the picture of an engine on it. Have you accidently pressed it? I did once just to see what it would do and experienced the symptoms you describe, considerable loss of power and black smoke after about 20 seconds.
Well folk I have my Bongo back and working well.
Firstly, as you all mentioned they thought it was the EGR opening, this was blanked of but the engine would still not rev up. So further fault findings found, that the rusty Baffle valve in the exhaust was jammed in the closed position. As the baffle is so rusty and would lead to further unwarranted expense, it was forced into the open position. The engine heater switch (part of the winter pack) and solenoid valve have now been disabled due to the fact that it will never be used in our climate.Unless the big freeze hits!!! as if!.
Total cost: £195.05 inclusive of pick up wagon.(£50)
One extremely elated Bongo bird.
- westonwarrior
