no aircon??
xpanse0
no aircon??
Post by xpanse0 » Thu Jul 26, 2007 8:34 pm
Can any one tell me what the possible problem is with my air con. It was working but it isn't as off a couple of weeks ago.
Thanks in advance
Steve
Post by francophile1947 » Thu Jul 26, 2007 8:44 pm
Need more info - do you mean it's no longer cold, or the fan isn't working?
dreamwarrioruk
Post by dreamwarrioruk » Thu Jul 26, 2007 8:45 pm
they will not work if they are out of gas, lift the bonnet and look to the right hand front side of the radiator, there is a small round block with a few pipes comming out of it. there is a sighthole in the top of it, someone said that changes colour when no gas in,they also said that if there is no gas then the aircon will not work to protect the system.
im sorry i cant help much but it might be worth getting the levels checked out and check for system leaks.
Naughtydog
Post by Naughtydog » Thu Jul 26, 2007 8:45 pm
can you be anymore specific,
do you switch it on and it doesnt work?
does it not get cold enough?
does the blower still wok on all speeds ?
give us a clue about what exactly doesnt work and then we can take it fom there.
