brorabongo
Post
by brorabongo » Thu May 31, 2007 10:43 pm
simple question, I hope
Is there different qualities of tap washers?
If so, which is the
best to go for?
Mine don't seem to last long (bought from a local hardware store) I have a oil fired combi boiler (hot is on mains pressure) the taps are Bristens of Birmingham 1901, and the washers are only lasting a year-ish the first one split and now the replacement is dripping (so is the wife!). I dont think the taps are needing reseated, but there again i'm no expert.
Cheers.
Donald
p.s. "so is the wife" is figuratively speaking
ボンゴの激怒 pictures
Run your fingers over my Bongo, and I'll run my Bongo over your fingers!!
pippin
Post
by pippin » Sat Jun 02, 2007 9:58 am
Looks like no plumbers on here!
Mark you they are no longer called plumbers, after all they no longer work with lead.
Even copperers is out of date, should we call them plasticers now?
jimsmimm
Post
by jimsmimm » Sat Jun 02, 2007 10:48 am
heating engineers I think their called now pippin.....or was that last week....
pippin
Post
by pippin » Sat Jun 02, 2007 11:02 am
Nah, fluid movement operatives now!
Post
by francophile1947 » Sat Jun 02, 2007 11:12 am
Getting back to the subject - I don't know if there are different grades of washer but, as the washer isn't lasting long,. suspect that the tap needs the seat re-cutting. You can get a tool from B&Q(or similar) for a few quid and it's usually an easy job - just don't overdo it.
twobikemike
Post
by twobikemike » Mon Jun 04, 2007 12:28 pm
My youngest is an apprentice Heating Engineer/Plumber and is always being told by the others in the company - "When asked what your occupation is, always say Heating Engineer. You don't want everyone to think you spend all day upto your elbows in other peoples s**t".
Hence, no more plumbers.
smartmonkey
Post
by smartmonkey » Thu Jun 07, 2007 1:08 pm
There are different grades and the older taps used to have hard washers that look like thick cardboard. The rubber type are compatable but you get better ones from the trade places. The seats may well need a bit of attention but there might be a simpler solution. When you put new ones in just be gentle with the tap. It only needs a slight twist to turn it off - just enough to not drip. The fairer half in particular tend to heave until they have wrung the life out of the tap.
By the way I love Brora, and particularly Dornoch. Golspie is a bit iffy though (dodgy people there).
brorabongo
Post
by brorabongo » Thu Jun 07, 2007 9:38 pm
ボンゴの激怒 pictures
brorabongo
Post
by brorabongo » Sun Jul 22, 2007 4:58 pm
At last, got round to changing the tap washer. (two minute job
) I have, just for now used a standard tap washer I had lying about. Next time i'm near a plumbers merchant, I will seek out good ones (If they exhist).
I would say the old washer has past it's best!
ボンゴの激怒 pictures
Post
by mikeonb4c » Sun Jul 22, 2007 5:57 pm
Things to do on a wet Sunday eh brora? (you'll probably point out it was blazing sunshine up there now!)
brorabongo
Post
by brorabongo » Sun Jul 22, 2007 7:39 pm
Not quite blazing
and with a little spit of rain. Nothing like what you lot down south are getting just now. Hope everyones ok.
ボンゴの激怒 pictures
Post
by francophile1947 » Sun Jul 22, 2007 8:37 pm
Hurry up to Norfolk Mike - a lovely sunny day here
Post
by mikeonb4c » Sun Jul 22, 2007 10:12 pm
Cant wait old son, cant wait. Got the coolant warning thingie fitted a treat so I can grin at it all the way over to you.
sirlarose
Post
by sirlarose » Mon Jul 23, 2007 8:58 pm
Now I know why we have had so many floods. It's his darn tap dripping
brorabongo
Post
by brorabongo » Mon Jul 23, 2007 9:41 pm
ボンゴの激怒 pictures
