pela and atf
karen
pela and atf
Post by karen » Sat Jul 14, 2007 2:06 pm
well just used the pela to suck the atf out
not the quickest but then there is nothing to do except watch so anytime will seem like a long time
seems to work very well though and is certainly a very clean method
still to fill her back up though but need to get a better funnel
got 3 and a half lires out - i assume that is about right
Vanmanerik
Oil Change
Post by Vanmanerik » Sat Jul 14, 2007 2:25 pm
Did you take it for a run for a few miles to get the oil warm before trying to suck it out, makes the job a lot easier and cleaner....
karen
Post by karen » Sat Jul 14, 2007 2:35 pm
afraid i didnt but i thought that wasnt valid for atf as it is not as GLOPPY as engine oil
i did think about it at the 1 litre point but it's not as if it's a rush
i mean it took 20 mins to suck it out -
Vanmanerik
Oil change
Post by Vanmanerik » Sat Jul 14, 2007 3:01 pm
It is nice to get other views and terminology on car and van topics, now I must add 'Gloppy' into my Oils and Lubricants entry. it has a lovely ring to it and describes the texture of cold ATF exactly. :)
I think if you had warmed it up by going for a 5 mile run, the van not you, it would have been an awful less Gloppy and not only would you have removed it quicker but you may even have removed more of it. Maybe next time...
Lewy
Post by Lewy » Sat Jul 14, 2007 5:05 pm
You might be able to get more out by jacking up the rear of the van - I did it on both sides and got about another 1/4 to 1/2 litre out.
karen
Post by karen » Sun Jul 15, 2007 10:42 pm
let her settle down and then set pela on the case agin
sucked another 1 litre out
Post by mikeonb4c » Sun Jul 15, 2007 11:11 pm
karen - will you now be taking the ATF pan off and cleaning the filter etc. or are you just going for a fluid change. Does it matter not cleaning the filter etc?
I'd be tempted to do my ATF if all that was required was to suck out the old and put in some new, but dont fancy the faff of taking the pan off, cleaning the filter etc. esp. as my fluid seems in good nick!
Mike 8)
ChrisEm
Post by ChrisEm » Mon Jul 16, 2007 8:02 pm
I cant see the point of doing an oil change unless you're going to take the sump off and clean the filter. Theres a magnet in the sump which collects any particles that accumulate through normal wear and tear and is worth cleaning. Additionally the oil in the bottom of the sump tends be creamy and thick, I wouldn't be confident I could remove all this with a pump.
