Air Con/Heater not working -smoking
gazza
Post by gazza » Sun Jul 08, 2007 9:44 pm
Had a bit of a scare yesterday, smoke started coming through the vent in the passenger footwell.
It only happens when the aircon is on, I guessing it might be the heater fan motor.
We haven't used the air con for a while due to rain.
Has any one else had the same problem?
Need to work out what bits need replacing and where to get them.
Any advice gratefully received.
Garry
Vanmanerik
Smoke.
Post by Vanmanerik » Sun Jul 08, 2007 10:55 pm
Lift the bonnet, remove the plastic air intake from the fan assembly, can you turn the fan? If the answer is no or yes but very stiff then remove the fan assembly and lubticate the fan bearings.
