ebay rad
ebay rad
Hi all,
Just bought a new radiator from ebay, after being offered 2nd hand radiators for a hundred quid!
I feel a little silly asking but is there a difference between the auto and manual radiator?
Needed the part asap and it was a good price but just a little worried now that I'll get it and its naff!
ebay rad
Hi Hector
Look carefully at the top of the new rad. It may have an 'overflow pipe' at the side of the radiator cap. You should find that your knackered rad hasn't got the said pipe. If that's the case, you need to blank that pipe off on your replacement unit. Two jubliee clips, a three or four inch length of hosepipe with the correct bore size and an appropriate bolt rammed up one end should do the job.
Members of this site are developing a healthy paranoia about overheating Bongos. Would you plesae explain the circumstances of your rad's demise.
Hope all goes well. Check the site for detailed info on bleeding.
Take care
Pat Mc Kenna
Take care
Pat Mc Kenna
- haydn callow
- Peg leg Pete
New rad.
I think you will find the header tank should have the pressure cap Harry, rad should just have a cap. It can still let off steam if necessary but it does it at the header tank, not the radiator.
- Peg leg Pete
Pete, are you referring to :-
A) 'Auto boxes usually have an oil line going into the radiator for additional cooling/heating. If the radiator has it and you don't need it it will be easy to block off but the other way round will be a problem. You need to have a look under your Bongo to make sure. The lines will be very obvious.'
or
B) 'Look carefully at the top of the new rad. It may have an 'overflow pipe' at the side of the radiator cap. You should find that your knackered rad hasn't got the said pipe. If that's the case, you need to blank that pipe off on your replacement unit. Two jubliee clips, a three or four inch length of hosepipe with the correct bore size and an appropriate bolt rammed up one end should do the job.'
or
- Peg leg Pete
