Top Hose
Top Hose
Driving along today i noticed a smell of hot water, noticed the tempeature guage was rising at an alarming speed. I pulled over and stopped in a cloud of steam!. After it had cooled i noticed a split in the top hose on the bottom s- bend.
The question is this. After i have replaced the hose, how do i best top up without getting air in the system?
Cheers Alan
Cheers Alan
- haydn callow
You already have air in the system. Replace the hose and properly bleed the whole system by the book. Coolant loss alarm may have forwarned you.
How many bongos have been reported in the last month with coolant problems ? We know a lot of them are caused by old hoses but I really don't see how peeps can say fitting a alarm is a waste of time and money.
Preventitive maintainance is all well and good but how many of us are good at it ??
Harry
Blobber
There has been lots of posts about bleeding the system recently.
It really is quite easy.
Try the search tool or ask Pegleg Pete
I had a burst hose (bleed hose) go in a similar fashion a few months back.
The short version of bleeding to get you going again.
1.
Wait till engine cools down.
2. Undo expansion tank top.
3. Fill to top with coolant (for preference) or clean water is nowt else is available.
4. Replace cap
5. Remove bleed hose end and hold up with end about the height of the expansion tank.
6. Start engine
7. Slowly lower end of bleed pipe until you get water or bubbles coming out.
8. Seal end of bleed pipe.
9 Switch off engine.
10 repeat proceedure until all you get is coolant or water out of bleedpipe.
This has worked for me on several occasions.
Nurse your vehicle home and then repeat with care making sure to top up your radiator before you first top up your expansion tank.
good luck
H
1.
4. Replace cap
6. Start engine
good luck
H
Bonza
Can I recommend the Bongo Coolant low water detector kit.
Developed from an already successful Australian system exclusively for the Bongo/ Freda and thoroughly tested. Full fitting instructions from the Club also.
Peace of mind at a very reasonable cost.
Dealer inquiries welcomed also. Please email Haydn for dealer supply info and costs.
[email protected]
Bonza
[email protected]
Bonza
Harry
Have a look and see if you can identify the colour...red or green...whatever it is don't mix the colours. Otherwise I don't think it makes a lot of difference which 'make' you use....they probably all come from the same manufacturer anyway.
If filling from scratch make sure you flush the system fully with fresh water before putting in coolant.
cheers
H
cheers
H
