Shudder when idling at low revs
Posted: Fri Feb 23, 2024 4:12 pm
by NLB2024
So quick question, my 1996 2.5td starts first time, but when idle the revs seem to fall to around 600, which makes the whole bongo vibrate quite a bit. If I touch the accelerator and get it to 800 it's as smooth as can be, any one know how I get it to idle at 800 to solve the issue?
Advice appreciated !!
Re: Shudder when idling at low revs
Posted: Sat Mar 02, 2024 11:42 pm
Does it stay at 600rpm even after the engine has warmed up. If it does then you might suspect the cold idle solenoid being faulty. I have one of these on my Bongo
https://dynad.co.uk/eagle-cruise-control
Apart from being able to use it as a cruise control of sorts, its handy for locking the throttle at any desired engine speed. Not really a proper solution but at least a workaround of sorts. I'm not technical enough to advise on adjusting tickover on the fuel pump etc I'm afraid
Posted: Mon Mar 25, 2024 5:42 pm
by Alkers
