My repair man took out the ABS fuse. I have put a new one in, but the ABS light is still on.
Do I have to do something to clear the error and if so, how?
ABS light on
- Junior Bongonaut
- Junior Bongonaut
Re: ABS light on
I have used the diagnostic port and got the following error codes -
53 Motor or motor relay
11 Right front wheel sensor
- g8dhe
Re: ABS light on
Usually the wheel sensors are either a connector that has leaked water in, try unplugging the intermediate connector, cleaning and WD40 into both sides before reconnecting, otherwise it maybe a damaged sensor coil itself.
The other as it implies will be within the controller module.
- Junior Bongonaut
Re: ABS light on
That'd be the one under the starter battery. I will do that tomorrow and also clean the fuse connector.g8dhe wrote: ↑Thu Feb 22, 2024 7:58 pm Usually the wheel sensors are either a connector that has leaked water in, try unplugging the intermediate connector, cleaning and WD40 into both sides before reconnecting, otherwise it maybe a damaged sensor coil itself.
Re: ABS light on
Got to be wheel sensor
