Climate control bulbs
Hello guys, thank you for welcoming me to the forum!! Unfortunately I have a problem with my climate control bulbs, I was able to replace them but the wedge bulbs are the wrong colour and it seems to struggle to illuminate the bottom right hand corner (AC,MODE,REAR, TEMP buttons), and I have also lost the original bulbs and holders so I can't even repair these, I was wondering if the LED bulbs are any good? Or is there anywhere else I can get replacements and also, what size/code are these bulbs? Thanks again
- g8dhe
Re: Climate control bulbs
If there the type that fit on the holders then there wire ended 12 volt pea bulbs easily available on eBay and other sites, but you need to have retained the holders to wrap the wires around. https://www.google.co.uk/search?num=100 ... +pea+bulbs
Ahhh damn it!! Looks like I am going have to do a good search to find my lost bulbs, thanks, hopefully I can find them and get some pea bulbs
There are 2 types of bulb for climate control, both obtainable from Mazda parts depts. The one at the bottom right is G09C61C95. The others are G09G61C95.
