Hi guys, just noticed a small patch of coolant on the road side, under the rear heater control box. Looks likely that the metal pipe that feeds into the unit is corroded.
I’ve heard of methods to blank the rear system, I’ve never used the heater in the rear anyway. Can anyone point us in the right direction?
Many thanks
Rear heater box leaking.
- Junior Bongonaut
- g8dhe
Re: Rear heater box leaking.
Kits in the shop but you need the right version as the pipe sizes changed https://bongoland.co.uk/?s=rear+heating ... pe=product
- Junior Bongonaut
I’m guessing the kit for a series 1 & 2 is fine, Geoff? Mines a 94. How far up the system do these install? Is there a guide or any pics online?
Many thanks
Many thanks
- g8dhe
No personal experience myself of sealing it off. I have always retained and use the rear heaters! However there are plenty of discussions on the board regarding sealing the heating matrix off as its a common problem.
Hello
I sealed mine off on a 2001 2.0ltr petrol model using 15mm copper pipe with 2 elbows. Just created a loop after removing the rubber pipe connections from the rear matrix inserted the copper loop into these and bunjie corded it up to stop it moving around under the vehicle. .Very simple procedure and effective.
- Junior Bongonaut
It seems the T- Junction is also in need of a bit of TLC, it’s slightly damp. Anyone got a guide to bypass this without the need to replace the whole pipe?
Many thanks
Many thanks
