Air con belt
- Apprentice Bongonaut
Air con belt
Hi any help will be appreciated just changing alternator belts and when I got the van it never had a air con belt so I got the full set of belts but for the life of me can't get the air con one to go on its a 13x 1000 it seems a little small is there a bigger size I should be getting
- g8dhe
Re: Air con belt
You don't say which engine but this is for diesel viewtopic.php?p=719904#p719904
Re: Air con belt
It's the 2.5 diesel 1995
Re: Air con belt
Make sure the tensioner is loose so the belt can slip on. I know one of the belts in the system seems waaay too small until it actually goes on and then it's fine. Hope you get it sorted.
