The temperature gauge My 2000 model 2 litre petrol bongo would never show the temperature going much past the cold area, occasionally when sitting in traffic on a hot day it would just record going past the first line for warm. I always thought it must not have a thermostat installed. The car never overheated.
Yesterday I took my bongo over to my mechanic. He said it did have a thermostat and it did appear to be working . He said the temperature signal sender did appear past its use by date so he replaced both the thermostat and signal sender.
He let the engine idle for a while and the temperature gauge was at 11,00 o’clock perfect I though.
Started to drive home and the gauge started to go down and after a few kilometers the gauge was back on cold again. Let the car idle at home and the gauge slowly went back to the 11 o’clock position.
I assume this is not normal the mechanic advised that the engine was reaching normal temperature but the gauge goes down when I drive I know it is winter here but would have thought that was the job of the thermostat.
Any ideas would be appreciated
Another Temperature guage question.
- g8dhe
Re: Another Temperature guage question.
Ah right just replied to the same post on FB;
The electronics around the display cause the needle to stay at the 11:00 position until its well into the HOT temperature range by design - this can cause much confusion see here to alter http://www.g8dhe.net/bongo_images/TempG ... pgauge.pdf
However that doesn't appear to be the problem your suffering, I wonder if the new thermostat was tested before being installed, because it sounds like it was open and allowing an excessive amount of cold coolant into the system!
- haydn callow
Sounds pretty normal for a 2ltr….they do run cool…..you can blank off a section of the rad if you want things a bit warmer.
