Door locks
Door locks
Hi guys just wondering as I can't see the answer via google what is the difference between the locks as ones for air bag and none air bag I assume that's its more to do with the ignition
- g8dhe
Re: Door locks
Re: Door locks
The steering locks are (apparently) different between airbag & non airbag models.
There wont be any difference in the door locks barrels.
On that note has anyone found a supplier of blank locks so I can make it up to suit my key? Some scumbag (unsuccessfully) tried to break in to mines last week the lock face is damaged. I have OCD about having different keys/locks so not putting a different barrel & key in.
95 2.5d 4WD AFT
Re: Door locks
Thank you guys I did mean the barrel and not door locks but all good as I've just sold a set but doesn't need the ignition. While we're on about locks seeing a few ppl have had there's done over is there a Anti tamper one that fit know the ones that take a round key
Re: Door locks
The tubular locks are a waste of time, there are tools available online that can open them with practically no skill whatsoever.
The other issue is you could get the best hardened, drill & pick resistant locks but at the end of the day they are mounted on a piece of sheet metal a few mm thick. They just puncture the metal around the lock with the screwdriver & pop it out of the door.
95 2.5d 4WD AFT
