Done a bit of an extensive search on here, but to no avail..
How does one go about removing the outside trim molding directly below the driver/passenger's door window.?
Part on the link here. http://lushprojects.com/bongopartsmk2/c ... no=.html#2
I've had a bit of a tug. but it wont budge..
Part 50-640?
Part 50-640?
- g8dhe
Re: Part 50-640?
Looks like it uses the clip #2 at the bottom 50-649B which looks like it needs to be twisted to pull the locking part out first maybe ?
Re: Part 50-640?
Hi Geoff, Hope your well..?
Yeah, four of those clips & the moulding looks like it clips over the outer door skin the same way the door card does on the inner skin..?
I'm almost thinking the door card may need to come off to allow a little "play" in the rolled down window in order to unhook this rubber edged (on the topside.) trim?
