Hi folks,
Does anybody know why our Airbag light is now flashing a few times, then stops for a few minutes, then flashes again. Plus, the horn is not working.
We have just collected our Bongo from being converted, and I know they did disconnect the battery, if that has anything to do with it?!
Thank you
Airbag Light intermittently flashing on dash and horn not working
Mazda Bongo 2.5l V6 Facelift Tin Top. Original Reg 2000UK Reg 2013
Re: Airbag Light intermittently flashing on dash and horn not working
Was the problem there before the conversion work?
It is likely related to the work they have done during the conversion after all they would have been in among the electrics and probably just dislodged a connection.
I would be looking for them to rectify their error before getting yourself involved with airbags.
I've had enough problems trying to get the work finished, 3 1/2 months for an initial 4-6 wk job, as quoted. I'd prefer just to get the issue sorted out myself.Bongolia wrote:Was the problem there before the conversion work?
- Muzorewa
Turn the steering wheel lock to lock a few times, is there any grating sound at one extreme or the other?
If they've had the whole steering wheel assembly off and the front wheel alignment has moved before it's been refitted, the airbag clock-spring could be broken which would explain both symptoms. Both will be an MoT fail of course.
Blimey!
I would still be writing to them asking them to rectify the fault in a reasonable period of time say three days and by a specific date.
If they didn't, wouldn't or couldn't then I would put them on notice that you intend to get the fault rectified elsewhere and give them the bill. Could be potentially expensive job and as previous poster states it is an MOT and safety critical issue and could invalidate your insurance in the event of an accident.
Incidentally in a small claims court/ money order situation you only have to show "probability" and it seems very probable that they have damaged the unit during the fitting.
Best of luck m8
Best of luck m8
Certainly sounds like the clockspring. I'd make sure that it could have been them causing the problem before I started talking about putting them on notice or taking small claims court action. Seems unlikely that any work they have undertaken during the conversion could have caused it unless they have done other work as well. Could just be coincidence, does happen.
Kimbals.
Is this same problem you posted about in March or was that resolved?
