Hi All
I noticed today a faint "hum" coming from the area very close to (or actually from) the EHU plug in the side of the van. The fridge is switched off. I have a Power Management 3 system and Split Volt Relay to the leisure battery.
TIA
Graeme
Humming from EHU plug area
- g8dhe
Re: Humming from EHU plug area
The PMS unit has the battery charger / 12 volt supply in it so that is what you can probaby here assuming its plugged in and powered up!
Not plugged in. Sorry, I should have been more clear. I can hear the hum when not plugged in and engine off with keys out of the ignition.
Graeme
Graeme
Sorted.
I believe the humming is the fridge. It continues even after being switched off
Graeme
Graeme
