The above Bongo Club Videos work correctly on MS Windows.
Android systems do not have a built in codec for mp3 music
or animated gif files. There is an animated graphic in the
introduction which I might remove for your convenience,
and there is background music which will not play in native
Android systems which will not be removed, you either hear
it or you don't.
You can install Apps from the google 'Play Store', you must
be carefull that you choose the correct versions. If you are
using an Android system , then it would be sensible to ignore
the inconvenience in this instance, and blame me for Google's
ommissions.
I do not have an Apple Ipad, but I have been told that the
Apple system does play the mp3 and background music
correctly, perhaps someone can verify this.
2sticks
mp3 codecs
Re: mp3 codecs
All videos 100% on my Mac.
