Hello all
I am considering replacing my existing 15 inch steel wheels on my 2 litre petrol with 15 inch alloys. There seems to be a bewildering array to choose from and I wondered if any member could recommend a particular make that fits well, ideally without the need for spacers, and is a reasonable price. I would probably opt for new tyres as well so any recommendations for those would be gratefully received. Current tyres are 215 x 65 x R15 100H.
Thanks in advance
Alloy Wheel Recommendations
Moderator: Ian
Re: Alloy Wheel Recommendations
Stick with steel, you can't go wrong.
I haven't bought a new tyre in the last six years, just other people's unwanted steel wheels with slightly worn tyres on them
I've now got enough wheels/tyres to run winter tyres if I want and to keep a front sized spare under the van and a rear sized spare at home. In one deal I got 2 wheels and four tyres for £50.
If the alloy look is what appeals, there are looks of eye deceiving wheel trims available. No hassle, no slow leaks, no cracked wheels when kerbing hard, cheaper tyres usually.
If you weren't in Yorkshire, I'd probably buy your steel wheels!
Frank
Frank
They flew, I took up naturism
By the sounds of it Frank, sounds like you should be living in YorkshireDiplomat wrote:Stick with steel, you can't go wrong.
Frank
- Simon Jones
If you change the wheels you ought to let your insurance company know. Mine came with original Mazda alloys which were in need of a refurb, but afterwards they look pretty smart and there are no worries about inferior aftermarket wheels.
Maybe someone will suggest some alloys soon but I think these are great.
http://igmaynard.co.uk/bongo/forum/view ... ep#p631002
It might be worth considering 17" wheels as you can then fit suv tyres which are widely available - this is if you want good off road grip.
Do consider the load rating of the wheels. I'm not sure what the recommendations are but our alloys are rated at 750kg which is quite high I gather.
Thanks for all the replies - food for thought!
