My driver window was working intermitantly but has now stopped altogether.
Have checked the wiring and all seems well, getting power to the electric motor connector but the motor not working.
Is there a fix for this
Thanks in advance
electric windows
Re: electric windows
Try spraying loads of electrical contact cleaner ( available from Halfords for approx £3.99 for a large tin! ) all over the motor ect. I've had no ends of 'stuck' electrics on our Bongo .... horn press's / rear blind switches to name a few .... all working 100% now thanks to a quick spray with the cleaner
Could of course be the motor's knackered, will be plenty available if it is, search for the cheapest around as prices on spares vary so much!
Good luck ....
Good luck ....
Thanks for that, will give it a spray when i get the door skin off.Gixermark wrote:Hi
Good luck ....
I think I will be taking the door lining off and looking at the motor as my driver's side window is now playing up.
Quite by chance I happened to have the radio turned slightly up on a quiet frequency and heard the switch connecting on both up and down movements without the window moving so I don't now suspect the wiring, unless it's a fault in the 'auto' up down unit which may not always be functioning despite me hearing the spark of the switch.
I wonder if the 'auto' module can be bypassed for test purposes.
Why can't car door panels have a hex socket for recovering the window like they do for electric sun roofs. Rain doesn't just fall downwards.
Frank
Frank
They flew, I took up naturism
The point has been made before but when searching and ordering cheap parts consider getting them delivered to somewhere other than home. If the person selling them (on ebay and the like) is not quite as honest as you would like, they then get your address and the likely home of another Bongo to break up for more parts, to sell on ebay and the cycle goes round again!Gixermark wrote:
Good luck ....
Always get Amazon and eBay purchases sent to my work. Also eliminates trips to the post office / carrier depot to collect when I am not at home because I am at work!!!
