units above side conversion
Moderator: Doone
turfite9999
Post by turfite9999 » Fri Mar 05, 2021 7:00 pm
Hi Guys hope you are all well,
I am making some lets say top units or overhead units/cupboards above windows has anyone any ideas on how to fix them to the van please
Thank you
Tony
Re: units above side conversion
Post by g8dhe » Fri Mar 05, 2021 7:36 pm
often use the high level handgrip mounting positions as the main fixing and then additional screws are added in some designs I suspect to ensure stability at the ends.
Image Spherical Visions
turfite9999
Post by turfite9999 » Fri Mar 05, 2021 7:49 pm
oh yeh thats a good idea Geoff i`ve lots of stuff going on with bongo and thank you again
Tony
Roy748
Post by Roy748 » Sun Mar 07, 2021 7:24 pm
Hello
I used the high level hand grips but avoided drilling any holes by using a 30mm × 1000mm strip of 90 decree aluminium . This I placed between the roof of the van and the floor of the aft. With my cupboards fixed by the hand grips it cannot move forward so the purpose of the bar is just to stop it dropping. Works perfectly without the need for any drilling.
turfite9999
Post by turfite9999 » Mon Mar 08, 2021 7:37 pm
thank you for that Roy it is appreciated
