Lowering???
Moderator: Ian
Re: Lowering???
That's a good price
Makes mine look dear
Re: Lowering???
Can recommend Springcoil, they made mine and fit perfectly. I went for 30mm drop and 25% uprated. These work well with my 17" wheels... the Bongo feels much more stable at speed and I can take corners better. Negotiating speed-bumps is fine too, I wouldn't go any lower than this though.
Re: Lowering???
Can you post a pic of you van, and confirm the distance from the top of the wheel arches to the ground. I need to decide what drop to go for. Thanks
Re: Lowering???
I would, but not sure how to add images to my post on here?
Re: Lowering???
Thanks, I have put the picture on Photobucket but it still doesn't appear on the post, just the URL address?wonkanoby wrote:http://www.igmaynard.co.uk/bongo/forum/ ... =42&t=9285
Re: Lowering???
Copy all
Where it says image ..................
On the right hand side of photobucket
Then paste onto here
- Bongonaut
Re: Lowering???
I can get hold of lowering springs from Japan but there not cheap expect to pay £200 for a set.
- Apprentice Bongonaut
Re: Lowering???
I have just ordered a new set of the RS-R down lowering springs from Japan. The shipping cost was more than the springs unfortunately
Lowering front: 45mm-40mm
Rear: 40mm-35mm
Spring rates
Front: 3.75kg/mm
Rear: 6.3kg/mm
There’s a set for the 2.0 and different set for 2.5 available.
Not sure how successful it will be, or if they will stay on.
But there’s only one way to find out. Expected back end of May so will update when they arrive.
Rear: 40mm-35mm
Spring rates
Front: 3.75kg/mm
Rear: 6.3kg/mm
- g8dhe
Re: Lowering???
Hope you don't expect to get across rough camping fields with them then! Seen a couple of undertrays ripped off because of that!
Re: Lowering???
Welcome aboard.
Guess it depends on how you use your Bongo, do let us know how it works out.
