Schematic Diagrams - Lushprojects
- g8dhe
Re: Schematic Diagrams - Lushprojects
OK, Thanks to dandywarhol and dave_aber who were first up, but a few more wouldn't go amiss, no great expertise is necessary, just a willingness to follow around a few web pages and report back if they make sense and work as expected. PM me with the button below the message and I'll send you details of the site.
- g8dhe
OK the Bongo Wiring Manuals are now available on-line.
The Club has two manuals at present;
November 1997 thru to January 1999, this manual is now available see the link below,
May 1995 thru to October 1997, this manual is now available see the link below.
Post January 1999, Ian believes he can locate a copy on CD if so then we will add this to the collection.
The link to the web site is here, click to enter:
It can also be found in the Database section on the club site.
If you hover the Mouse over the Covers it will show you what VIN's are covered and clicking the Cover will take you into the required Manual.
It is well worth reading the Help screen on how to navigate around the images and pages.
Many thanks to those who have contributed ideas, info, time and have been helping with the testing;
Ian - Bongo Master
momogiraf - Translation
Ron Miel - VIN checks
dandywarhol - Testing
dave_aber - Testing
Ian - Bongo Master
dave_aber - Testing
- missfixit70
Good work on the wiring diagrams
Yes well done Geoff. Now when we get a question on electrical problems, we can refer some of them to your link. Whew.
Allan's closed. in Plymouth we recommend PGS (Plymouth Garage Services) or Mayflower Auto Services
- g8dhe
- dandywarhol
Could it be anything to do with the brake light circuit being constantly live and used to clear ECU fault codes? Being a bit of a numpty, I searched for ages looking for number 31 - then discovered its 3I, the letter before J
- widdowson2008
Hi Geoff
1st impressions - Excellent - easy to navigate - STERLING job - Surprised at the clarity
Steve
- g8dhe
Well its better than anything I can think of at the moment !dandywarhol wrote:Could it be anything to do with the brake light circuit being constantly live and used to clear ECU fault codes?
dandywarhol wrote:Being a bit of a numpty, I searched for ages looking for number 31 - then discovered its 3I, the letter before J
Yes I hate some Fonts for that I mean good old Arial has the following lIıΙІ׀ﺍ that's 8 different but nearly identical symbols in the one font
- g8dhe
Yup you can actually Zoom in even more, but its to easy to loose yourself! But it really helps on the Location diagrams - all the Odd numbered pages 19 to 137 - as you can see where the connectors physically are in the vehicle. I've kept the Zoomed out small sizes so that you could just about use it with an iPhone with 480x320 pixels.widdowson2008 wrote:Surprised at the clarity
- missfixit70
You did better than me, I gave up, thought I was being daft Turns out I wasdandywarhol wrote:Could it be anything to do with the brake light circuit being constantly live and used to clear ECU fault codes? Being a bit of a numpty, I searched for ages looking for number 31 - then discovered its 3I, the letter before J
Brilliant job there, Geoff - many thanks to all those involved. A very useful facility.
Just one question - are either of them downloadable, so we can put the relevant one on our FactSheet memory sticks?
Mike
Mike
Curator of the Bridgwater Motorbike Collection
- g8dhe
Not downloadable as such I'm afraid (that wasn't the remit ), as they are designed for web presentation and hence need an http server of some sort to supply the files, each image has been split into several hundred parts so that you only download what you need when you need it, otherwise you don't get the resolution when zoomed right in. All the files (226,000 of them ) together amount to 1.5GBytes.
I do have the high res. scans of the sheets, but they amount to some 6GBytes worth ...
Ian can still supply the original CD's with the sheets as a PDF if you want them to carry around with you.
The 1995 is still being worked on just finished sheet 92 a few moments ago ......
You get all the fun jobs.
- g8dhe
The fun bit is thinking up how to do it
The nice bit is automating 99% of the drudge bits
The tedious bit is that 1% left that can't be de-drudged
Still it was strangely enjoyable working out that 空 meant Sky Blue
Handbrake switch maybe? its often used to disable TV/DVD screens when driving.g8dhe wrote:Can anyone work out why the Brake lights signal would have been brought up to the radio/Audio system (connector 3I) it certainly doesn't appear on the ISO connections
1995 Ford Freda, 2.5TD, auto, AFT, side conversion.
