Camping Gaz 904 & 907 Cylinder - Weight - Volume
Moderator: Muzorewa
Post by g8dhe » Wed Sep 09, 2009 11:52 am
I needed to check out our Gaz cylinder today to see how empty it was so put this chart together to make looking up quicker in the future.
The Cylinder is marked around the rim with its empty weight (3.6 Kg) and weight of gas it holds (2.95 Kg).
From other discussions on the forum the 904 cylinder is 3.00Kg and holds 1.8Kg of gas,
and from the web the 901 cylinder weighs 0.26 Kg and holds 0.45 Kg.
If anyone has the values for other cylinders I'll add them as well.
Click the link below for chart;
Camping Gaz 907 cylinder
Camping Gaz 904 cylinder
Camping Gaz 901 cylinder
Image Spherical Visions
technophobe
Re: Camping Gaz 904 & 907 Cylinder - Weight - Volume
Post by technophobe » Wed Sep 09, 2009 12:48 pm
I recently wieghed a 607 cylinder on the bathroom scales. Full it weighed 6.40kg which means that the canister weighs 3.68kkg. Weighed a nearly empty one and found there was 1/2kg gas. Good saving.
Richard & Jo
apole
Post by apole » Tue Sep 15, 2009 11:21 am
Thanks Geoff, that is very useful.
Andy
sdsk
Post by sdsk » Thu Mar 28, 2013 9:57 am
I emailed Coleman (current owner of Campingaz) about this and received the following reply:
"The empty weight of the R907 is 3,9kg (6,65 full) and the R901 is empty 1 kg (1,8 kg full)."
The 907 figures are around the same as those measured, but the 901 is quite different.
My graphs are here:
https://dl.dropbox.com/u/49798743/Gas%2 ... Graphs.pdf
I hope that helps rather than confuses matters.....
Darron
2001 Aero 2.0l JAL Skylift roof & K2 Campers Intrepid Rear conversion in Carbon Fibre
Poohbear
Post by Poohbear » Thu Mar 28, 2013 10:11 am
I usually just pick it up and shake it. I think I can pretty much tell if it's quarter, half or three-quarters full that way :D
mikeWalsall
Post by mikeWalsall » Thu Mar 28, 2013 1:12 pm
I would have thought the lighter weight, see through, re fillable cylinders would have become a lot more popular than they seem to have ..
tcflinty
Post by tcflinty » Thu Mar 27, 2014 12:43 pm
I recently saw a little device looked like a Pen , all you had to do was run the pen down the side of your canister and it indicated how full it was , now I have tried ti find one of the helpful little tools but had no luck.
If any one as seen them or they use one would you let us know .
Flinty
Poohbear
Post by Poohbear » Thu Mar 27, 2014 1:01 pm
tcflinty
Post by tcflinty » Thu Mar 27, 2014 1:06 pm
Well done that man that is what I had seen advertised , didnt think they would be the expensive though , oh well such is life .
Thanks for that .
Flinty
PisceanJoy
Post by PisceanJoy » Fri Mar 28, 2014 1:24 pm
costs more than a gas canister :?
janie
Post by janie » Fri Mar 28, 2014 3:52 pm
Dodgey
Post by Dodgey » Sun Jun 22, 2014 9:44 am
Poohbear wrote:I usually just pick it up and shake it. I think I can pretty much tell if it's quarter, half or three-quarters full that way :D
Brilliant :-)
I was pondering the weight of my 907 the other day and my mate sighed, grabbed it, shook it, and said, "that's full mate". He was right :-)
Bobnwen
Post by Bobnwen » Sat Jan 16, 2016 8:43 pm
Thanks very helpful
