Stupid Question of the day.... Solar powered shed light ?
Posted: Sun Mar 11, 2007 11:25 pm
by Biddy
You might think me a complete numpty but I'll ask anywhoo. £14.99 local hardware shop. Full charge 2x AA batts powers 1 watt super bright flourescent lasts 1.5 hrs. panel 16.5cmx11.5 1.55m cable. Do you think it pos to use panel to charge anything bigger like a 6v motorcycle battery.
Thinking may be able to adapt for internal lighting. or portable dvd's and games. I dont' mind being called silly.
http://tinyurl.com/28ot8h this is same one only costs more.....
Posted: Sun Mar 11, 2007 11:29 pm
by Peg leg Pete
I think it will power the lamp fine, but the 6 volt battery will require a higher wattage solar panel
Posted: Sun Mar 11, 2007 11:32 pm
by francophile1947
Hi Biddy
You're a complete numpty!!
As it charges 2 x AA batteries, it's output must be in the order of 3 volts - have you got anything that needs so little power? Also, I suspect it would take a very long time to charge the batteries.
Posted: Sun Mar 11, 2007 11:34 pm
by moonshine
In theory it may be possible, but I wouldn't think it practical due to the length of time it would take to charge. However, solar panels which will charge quite large batteries are available, but at a price. Many of my boating friends use them to top up their leisure batteries ready for when they return to their boats the following weekend.
Posted: Sun Mar 11, 2007 11:42 pm
by Biddy
francophile1947 wrote:Hi Biddy
No harm in asking if you don't know... THANKS PEEPS looks good enough for children's DS
Posted: Mon Mar 12, 2007 12:10 am
by francophile1947
No harm at all Biddy - that's what the forum's about.
Posted: Mon Mar 12, 2007 12:13 am
Dandys the guy to answer this one. He's got a whopping big one and its stuck to his roof
Posted: Mon Mar 12, 2007 8:09 am
by moonshine
Brings tears to my eyes......
Posted: Mon Mar 12, 2007 11:58 am
by skyhigh123
You could try this from Maplins- reduced from £19.99 to £9.99. I bought one and certainly the LED flashes merrily during the day while it's attached to my motorbike battery. I've yet to be convinced that it actually works in terms of delivering a useful charge- (why are they selling them off cheap?)
http://tinyurl.com/yuwezp
Posted: Mon Mar 12, 2007 9:23 pm
by trevd01
Here's a little test:
Q:
The cheap maplins solar chargers are 1.5 watts = 0.125 amps.
If a leisure battery is 110 amp/hrs how long will it take to charge it from flat?
A:
Probably infinity, i.e. it will never charge it. Although theoretically, given 8 hours continuous sunshine every day, maybe
110 days.
I'm sure someone will correct me if my electro-maths is wrong!
{EDITED} And Franco did
Edited to show correct figure!
Posted: Mon Mar 12, 2007 9:35 pm
by francophile1947
Close Trevor - it would take 110 days at 1amp (8 x 0.125) per day
Absolutely useless for anything other than keeping an unused battery topped up.
Posted: Fri Mar 16, 2007 10:20 pm
by mp3oplecarrier
They are CLEARLY for supplying a top-up charge, particularly useful for vehicles like ours with lots of electrical goodies or vehicles that are not run often.
Posted: Sat Mar 17, 2007 12:05 am
by dandywarhol
Even my whopping big 'un on the roof only gives about an amp - as folks say, just enough to trickle charge it during the 20 hours of sunshine we'll have up here when the clock's change...........
