Page 1 of 2
bit of a leak
Posted: Thu Mar 08, 2007 12:23 pm
by clogger
seem to have developed a wee leak well more of a drip
if you look under the van from the drivers side there are 2 rubber pipes to the left hand side of the petrol tank that go up into the side of the van
just thought about it maybe something to do with the rear heater??
it seems to be coming from above both pipes dripping down both pipes does`nt seem to drip when the engines running
only whenn the engine is turned off and does`nt smell like coolant seems to be water as it not that sweet smell of coolant and not sticky to the touch
any ideas
cheers
Posted: Thu Mar 08, 2007 1:03 pm
by dandywarhol
Photo??????
Posted: Thu Mar 08, 2007 1:55 pm
by Ian
Have you been running your aircon?
Posted: Thu Mar 08, 2007 2:12 pm
by clogger
sorry peeps no photos
it just started today
went to asda to get that recomended upholstry cleaner
got back stopped the bongo drip drip drip
stops after a minute
not been using the aircon think i will go investigate further
but any ideas carry on but is it as i suspect the rear heater matrix maybe
would`nt have minded spent the morning sorting the bloody rear electrics out nice working rear wiper /demister and even the central locking now locks the tailgate aaaaggghhhh
so had the engine stopping and staring for that
bugger
Posted: Thu Mar 08, 2007 3:00 pm
clogger - you've just bought your Bongo. Whats the dealer guarantee - did they give one?
Posted: Thu Mar 08, 2007 3:04 pm
by neil/di
My money is its the condensate from your aircon like Ian says
Neil
Posted: Thu Mar 08, 2007 3:20 pm
by 2sticks
Aircon is a popular suggestion and I would agree especially if you have electronically controlled
air conditioning and you have it on Auto. You may have warm air coming out but it uses the freezer
first to get rid of humidity in the atmosphere and quickly clear the windscreen.
Posted: Thu Mar 08, 2007 3:22 pm
by clogger
i hope your right
as i say i have not been using the aircon
dealer has been informed and i mentioned it would be a better idea to take it to the bongo friendly garage over in huddersfield and he was fine with that so fair enough
few things i have noticed though even though theres no gurgling the temp slowly gets up to about 11/12 mark the bottom pipe still isnt warm
does`nt get any higher on the gauge the fan does`nt come on but it does work cos i`ve have seen it going ??
also the bottom 2 pipes under the rear matrix feel crunchy if squeezed so suspect theres crud in them, at the very least i think a good flushing thru and redo the coolant
its hard to see from the image but it`s leaking from above the pipe and dripping down the pipe
Posted: Thu Mar 08, 2007 3:32 pm
by 2sticks
If you do have climate control, make sure it's running manually and wind the temperature up to maximum.
If I run mine on auto in cold humid conditions it drips, if I run it manually it doesn't drip.
Worth a try.
Posted: Thu Mar 08, 2007 3:33 pm
Use your guarantee while you have it clogger - unless I've musunderstood, you've already said you havent been using the aircon. When I was inspecting Bongos, I noticed some had crunchy pipes and some didnt. I went for the latter.
Can anyone advise what might cause one Bongo of a certain age to have crunchy (a.k.a. perished pipes) while another one does not. I wonder if replacing pipes is a b****y good idea at start of ownership if crunchy pipe syndrome is detected :roll:
Posted: Thu Mar 08, 2007 3:43 pm
by clogger
i do not have climate control by that i assume you mean the digital version nah it`s manual all the way
and the only pipes that are crunchy are the two bottom pipes all the rest seem ok.
just waiting for a price of a new matrix if it is that think it will be going over to huddersfield just for a good once over
the rear heater wont be used much so i may just oik the pipes off and bypass it
or wait till dent and everones gone to sleep and swap it over :D :D :lol: :D
right i`m off to pull a few panels off to have a nosey now wheres that hammer
Posted: Thu Mar 08, 2007 9:39 pm
by Peg leg Pete
clogger I am was seriously going to go to Dent :roll: but not sure now :wink:
Posted: Sun Mar 11, 2007 8:26 pm
by clogger
looks like boris the bongo is leaving
told the dealer all about the problems etc and i was not happy about them
especially now it`s started leaking
it was meant to have had a new waterpump thermostat etc this i think has been done but the guy who did it has`nt flushed the system hence not nice bluey/green liquid but sludghy brown so nice new waterpump making all the system work how it should so the sludge has blocked up the rear matrix comes under higher pressure and pop it gives
so i told mr dealer nah not happy about all this gonna bring it back for a refund or replacement,
so have now done a deal on another one he has in black tinted windows just waiting registering so it starts all over again
shame though cos other than that i was now getting along with it
on another note i could always cap it off but it does`nt leak till system gets hot so is only a pin prick type affair
as anyone any thoughts on radweld on this
even though i am not keeping it now just curious
cheers
Posted: Sun Mar 11, 2007 8:52 pm
by dreamwarrioruk
wouldnt even think about using radweld. too much of a risk clogging up vital parts of the bongos cooling system for my liking.
Posted: Sun Mar 11, 2007 8:55 pm
Take it back clogger. And his next chance is his last chance. This shouldnt have happened :evil: :evil:
