drivers door panel removal
Posted: Fri Feb 23, 2007 2:29 pm
by trekie
hi all,
i need to replace the drivers door lock (somebody used the wrong size screwdriver to break in) i got the door lock from tom at bell hill (good man!) so now i need to know how to remove the door panel and i know that i can rely on all you sages out there to come to my rescue. thanks in anticipation.
regards
alex and jan
Posted: Fri Feb 23, 2007 2:38 pm
by Ian
If Pippin was here, he would say something really sarcastic like "Seek and ye shall find".
But I'm not going to say that. Oh no. Instead I will give you the direct link to the information you require:
http://www.igmaynard.co.uk/bongo/forum/ ... el+removal
Ofcourse, if I was a grumpy old b*gger, which I'm not, I could have said
USE THE BLOODY SEARCH FACILITY!!!
But as everyone thinks it's useless, I'm not going to say that either.
Posted: Fri Feb 23, 2007 2:56 pm
by trekie
thanks ian,
actually i did try the search so i will say no more. also, i dont have full access to the site because i dont have a home pc( i moved) and your server wont talk to my works server( or it would if you sold viagra or penis enlargements!)so i havnt had the password in months, are you still doing doing airports? let me know when you get to speke! ( thats john lennon airport in liverpool)
regards and i dont think you are at all grumpy =D>
alex and jan
Posted: Fri Feb 23, 2007 2:57 pm
by wrster
You don't need to unclip the rod off the interior door handle; if you've undone the screws in the handle, it can be fed through its hole as you lift the panel away by gently twisting it a bit.
When refitting the panel, lower the window first as it makes it easier. As for the plastic door liner, be wary of the black mastic that fixes it on, its a total git to get off. I was wearing latex gloves and the twang as I pulled my hand away truly stung!
