Page 1 of 2
Windscreen washers
Posted: Wed Feb 07, 2007 8:30 pm
by karl
Can anybody help.
The washers for both the front and rear have pact in, the wipers work, but in this weather not much good if the windscreen is covered in filth.
Also, Ive tried the old fix it method, (5lb lump hammer) still wont work, any ideas?
Posted: Wed Feb 07, 2007 8:56 pm
by Dabs
Is it the pump thats gone or do the pipes need cleaning out.Also check the nozzles on the bonnet stick a pin in em they might just be clogged up.
Can you hear the pump when You squirt the water?
Dabs
Posted: Wed Feb 07, 2007 9:11 pm
by dobby
They haven't frozen have they?
Re: Windscreen washers
Posted: Wed Feb 07, 2007 9:15 pm
by karl
[quote="karl"]Can anybody help.
Also, Ive tried the old fix it method, (5lb lump hammer) still wont work, any ideas?[I think it might be the pump, is it a complete unit that includes the bottle or are they seperate]
Posted: Wed Feb 07, 2007 9:18 pm
by karl
[quote="dobby"]They haven't frozen have they?
[not frozen as it is filled with an anti-freeze solution
Posted: Wed Feb 07, 2007 9:26 pm
by dobby
It's just that mine were this morning and I'd used 50/50 screenwash. It took half an hour to defrost them.
Posted: Wed Feb 07, 2007 9:33 pm
by Peg leg Pete
Ours was frozen too, strong mix of wash in bottle, but still froze, was a cold morning
Posted: Wed Feb 07, 2007 10:55 pm
Absolutely - I've never found antifreeze helps. I suspect the volatile antifreeze may evaporate from the solution on prolonged contact with atmosphere (as in at the jet exit) near the jet so you get a 'cap' of ice just near the surface. Anyone want to do a thesis on it
Posted: Wed Feb 07, 2007 10:58 pm
by francophile1947
Antifreeze in washers won't stop the small amount in the tubes freezing - mine regularly freeze when the temp goes below freezing.
Posted: Thu Feb 08, 2007 1:16 pm
by bigdaddycain
I didnt think you could use anti freeze in the washers? does it not damage the wiper blades over time? I dont use screen wash either, i put a couple of drops of t.f.r. in the washer reservoir, and it hasn,t froze yet, touchwood...
Posted: Thu Feb 08, 2007 1:27 pm
by francophile1947
I think the antifreeze is actually screenwash fluid.
What's t.f.r?
Posted: Thu Feb 08, 2007 4:08 pm
by karl
not frozen I checked, I think the pump might have pact in. I will have to strip it out this weekend, thanks everybody for your help.
Posted: Thu Feb 08, 2007 5:47 pm
by dp bradford
francophile1947 wrote:
What's t.f.r?
I think he probably means Traffic Film Remover. BICBW
Posted: Fri Feb 09, 2007 2:58 am
by bigdaddycain
Yes mate traffic film remover. I swear by the stuff, i carry a diluted spray tub in the back of every car,brilliant for alloy wheels, a proper brake dust shifter that is
Posted: Fri Feb 09, 2007 2:59 am
by bigdaddycain
Er, ... Whats BICBW?
