Sudden cut-out on motorway
UncleMatty
Post by UncleMatty » Sat May 16, 2026 1:36 pm
If you were heading up or down the m74 just South of Johnstonebridge on Saturday 2nd - I saw at least 3 fellow Bongonauts passing - you would have seen Auntie Bongo and I stranded on the hard-shoulder. I was happily trundling down lane one at around 55-60 when she just cut-out. Thankfully I was able to coast gracefully on to the hard-shoulder. I am a member of the RAC so was rescued and taken back home, though I did have to wait 4 hours, and the recovery driver apparently had received the call only 10 minutes before he set off to pick me up!
There were no real attempts to diagnose, and it appears no thought of fixing it once it was established it wasn't a battery issue; I had a portable booster which didn't help in re-starting, or fuelling error.
I'm hoping to carry out some checks, and possible repair myself before taking to a garage; there are a couple of candidates reasonably nearby, but neither offers tow, or mobile mechanic services.
I have done some initial diagnostics myself
1.As mentioned the booster pack didn't help with starting.[/list]
2.I have checked all fuses in the cab, and under the bonnet, with the exception of the high amp ones just behind the starter battery.
3.I have had the driver's seat up, and can see/feel the fuel cut-off solenoid activating when the ignition is turned to position 2.
I'd appreciate any pointers for things I could investigate with the caveat that I have no access to a pit, I don't have anything to raise and support my van safely either.
a. Auntie Bongo is a 1995 2.5 TD AWD AFT
b. I did fill up before I set out on my journey, and it was definitely the black pipe :)
c. Ignition turn-over seems fine and isn't "racing"; it was suggested this could be an indicator of a failed timing belt, I had that replaced around 6 months ago. I generally have no problems starting.
d. The glow plug light goes out after a few seconds as usual.
e. I've made a visual inspection, and apart from a bit of oil on the block, there are no obvious signs of leaks, certainly not from the fuel system that I can see.
Any advice gratefully accepted.
Matt
Matt
95 2.5 Diesel, AFT, Side Conversion
Re: Sudden cut-out on motorway
Post by g8dhe » Sat May 16, 2026 2:19 pm
Could be a blockage or water in the fuel filter water trap, try releasing the water trap to see if its blocked with water in the fuel? (White screw cap with leads on at the bottom of the fuel filter, it should light a warning lamp on dash but wires loose or blown bulb might stop the warning!).
Have you been able to check for diesel in the injection pipes to the engine?
UncleMatty
Post by UncleMatty » Mon May 18, 2026 4:59 pm
Hi Geoff,
I managed to get a gent from a garage just across the road to take a look, he's established that there is no fuel making it to the injectors. He found the solenoid; what I though was the solenoid wasn't, it is something related to cold-start, and thinks that it is not activating when the ignition is turning. He's going to have a proper look with his test kit in the next day or so. I'll update when I know more.
Matt
UncleMatty
Post by UncleMatty » Sun May 24, 2026 10:28 am
Update, Neil at Alexander Latto has diagnosed it is the solenoid, so I have one on order. All the tricks of the trade were employed to remove the old one since it was pretty much cold-welded on!
Fingers crossed I'll be back up and running in a few days.
Matt
Post by Bob » Sun May 24, 2026 6:54 pm
Appreciate the update, thanks.
UncleMatty
Post by UncleMatty » Tue Jun 09, 2026 11:00 am
Sorry for the delay I have been a bit busy of late. The good news is the replacement solenoid has sorted the problem. Auntie Bongo is back on the road, and has recently carried me from Edinburgh to Tywyn with no issues. The mechanic did point out though that I should probably invest in a replacement fuel filter assembly as the current one is in a bad state.
Matt
Post by g8dhe » Tue Jun 09, 2026 11:07 am
Ah excellent news, yes often the fuel solenoid or at least its wiring has proven to be a problem. I wonder if the wire feeding it gets a lot of wear internally due to vibration?
UncleMatty
Post by UncleMatty » Sat Jun 13, 2026 6:26 pm
Yeah, research seems to point to it being either physical or thermal stress causing the varnish to wear on the coil causing reduced functioning of the coil or a short. Great it was a relatively cheap and quick fix. On a less happy note, driving through a single track road in Gwynedd today, I cam across a branch sticking out of a bush, I wasn't quick enough to react, and it took out my nearside indicator lens and bulb :roll: . I have a replacement ordered.
Matt
