Diesel injector pump seals
Posted: Thu Oct 30, 2025 9:28 pm
by knewel
Greetings. First time I've posted. I'm putting new seals on 1999 diesel injector pump. I've followed the Fact sheet for doing new seals with injector on engine. (not easy, but I got it apart). As mentioned in Fact sheet--be careful parts don't fall on floor. I was actually able to grab all the pieces once I got front dome and backing plate off. (dropped into my hand). But... I'm not positive on how they go back in. I'm looking at injector pump schematic on-line and it doesn't look quite like what I've got. With a clear diagram, I'm good to go, but as it is now, I don't want to risk something in wrong order. Any clarity on putting these pieces (shims, metal cap, etc) back in would be greatly appreciated. Man, this is stressful work...
injector pieces.jpg (19.19 KiB) Viewed 3632 times
Re: Diesel injector pump seals
Posted: Fri Oct 31, 2025 11:32 am
by Doone
You'll be able to find a diagram on Lush Projects site.I hope it helps. https://lushprojects.com/bongopartsmk2/
Posted: Mon Nov 03, 2025 8:24 pm
by knewel
I'll try that, thanks! It seems pre 1999 diagrams are everywhere on internet. Post 1999...like hen's teeth..
