Rear washer pipe
Greenmachine96
Rear washer pipe
Post by Greenmachine96 » Sun Aug 17, 2025 7:55 pm
Washer motor seems to be working (noisy) fine, but nothing coming out rear pipes. I've disconnected the joint at the tailgate so I know it's not the actual jet. I've tried pulling the 6 inches of pipe out to find the one way valve but it's very tight. I risk pulling the valve out and losing the pipe in the roof space.
I was hoping to get round the one way valve and blast some air through.
Any tips/advice/thoughts?
Greenmachine96
Re: Rear washer pipe
Post by Greenmachine96 » Wed Aug 27, 2025 9:15 pm
Investigating further - it's definitely the main length of tube that runs from back of van to front. This seems very difficult to replace so how do I clean it?
I attached a bike pump to the the front end to try to blast some debris to through but nothing. Feels completely blocked.
Post by g8dhe » Wed Aug 27, 2025 9:50 pm
As I recall it runs up the "A" then behind the plastic all down the length of the van best to refer to the diagrams https://www.lushprojects.com/bongoparts ... mgno=.html
Post by Doone » Sat Aug 30, 2025 7:06 am
We've attached an airline ho the pipe under the bonnet and blasted air through before. But if yours won't blast then maybe its kinked somewhere?
Sometimes a motor will make a noise, but still not pump, because the impeller has failed and isnt spinning.
Greenmachine96
Post by Greenmachine96 » Sat Aug 30, 2025 1:35 pm
Thanks Geoff.
I took that panel off and found a very crushed pipe. Pinched it open and the watched the water flow! Very happy. Simple fix.
Now back to my PITA electric roof.
Post by g8dhe » Sat Aug 30, 2025 2:49 pm
Ah that's good!
