V6 Coil Function Checking?
Posted: Sat Jan 11, 2025 2:48 pm
by coppen
Does anybody know what the ohm resistance reading is on the coil?
I'm getting 1.1 Ohm across the white plug terminal.
Trying to eliminate ignition items to solve the misfire.
Is there any way to check the ignition igniter module?
Re: V6 Coil Function Checking?
Posted: Sat Jan 11, 2025 3:21 pm
Never seen any details for the coil and system. Probably best to remove each spark plug in turn and check that your actually getting a spark, its a reasonably quick and certain way of checking the basics of the system end to end.
Posted: Sat Jan 11, 2025 3:24 pm
by coppen
g8dhe wrote: Sat Jan 11, 2025 3:21 pm
That's first on my list...then I've a new fuel filter before looking at the coil then dizzy driver.
