Timing belt noise
Posted: Fri Jul 12, 2024 4:00 pm
by Garypnewman
Hello everyone,
Looking for advise on this noise from the timing belt. Is it just a simple readjustment and new belt or something more terminal.
https://youtu.be/8nLx6Q-yxSg?feature=shared
Many thanks in advance
Gaz
Re: Timing belt noise
Posted: Fri Jul 12, 2024 4:27 pm
The image shows the belts for Aircon (Missing ?) and the twin belts for water pump and alternator.
https://www.lushprojects.com/bongoparts ... mgno=.html
The timing belt is further back.
Posted: Fri Jul 12, 2024 4:39 pm
by Garypnewman
Geoff,
Yeh sorry miss named the belt. Any ideas on the noise emanating from the area looks like the pulley is moving, causing the noise.
Gaz
Posted: Fri Jul 12, 2024 6:08 pm
Not being a mechanic I wouldn't like to guess! When we listen to the recording its only a mono track so we can't identify where the sound is coming from, only you can do that, if the pulleys aren't loose then it really needs a mechanics view point who knows the particular sounds!
Posted: Fri Jul 12, 2024 6:42 pm
by Garypnewman
Geoff,
I agree after a little more research and looking at movement i pretty sure its the crank shaft pulley.
Ill get her to a garage to confirm.
Anyone have a rough idea how much a garage would charge to replace. I can see them for sale for anywhere from 70 to 150 depending age of the pulley.
https://youtube.com/shorts/rJC472mnvc8? ... ShzUeKvzC9
The rattle changes with revs.
Posted: Sat Jul 13, 2024 2:24 am
by Northern Bongolow
The pulley is a rubber bonded multi piece job. It is coming apart. It's hitting the front of the engine so don't run it .....
Posted: Sat Jul 13, 2024 10:06 am
by Garypnewman
Rgr that,
Im waiting on delivering of a spare and i have a mobile mechanic on standby to swap it out for me.
Gaz
Posted: Tue Aug 06, 2024 10:12 am
by Garypnewman
Just to update i had the crank pulley replaced and shes running without the noise now. When the old one came off the rubber had degraded and it fell into 2 bits. Cheers for the advice all.
Gaz
Posted: Tue Aug 06, 2024 6:58 pm
by Bob
Glad she’s fixed. 8)
