Heater Linkage passenger side
Posted: Fri May 24, 2024 11:40 pm
by Sophiemay
We are new Bongo owners and the air con has not been working in the front(is lovely in the rear) It is a 2l 2002 Tintop with digital dual climate control. We have narrowed it down to the passenger side Heater Linkage. If I uncouple it and pull it down the air con is cold if I push it up heat....How to I repair this? Is it the motor or does it connect elsewhere and that's the issue? Appreciate any help here please
Re: Heater Linkage passenger side
Posted: Sat May 25, 2024 9:40 am
No the servo drives the link directly nothing else involved at the mechanical level.
Is the servo making any noises as you adjust the temperature ? If not then it might be faulty itself or the the control module could be faulty. If it does make a small noise then likely the servo itself needs repair/replacing.
Posted: Sat May 25, 2024 12:40 pm
by Sophiemay
That's great, thank you, no noises to speak of. I've disconnected the linkage and pushed the thingy down for now in order to get the air con into the cab. Any suggestions on where I can buy a new servo? Thanks in advance
Posted: Sat May 25, 2024 1:33 pm
by Bob
Bongo Spares, near Sowerby Bridge, are a reliable source of used spares.
Welcome aboard.
Posted: Sat May 25, 2024 3:09 pm
I have this list of likely sources;
These companies do a range of spares, not all will have everything so try them all;
For smaller parts its probably best to ring companies as not all the smaller parts make it on to the web sites!
SPARES:
Bongo Land bongoland.co.uk/shop/ 0114-2550836
Mazda Bongo mazdabongo.com/ 01234-480808
Bongo Spares
www.bongospares.co.uk/ 07836-598528
Vosper Parts parts.vospers.com/ 01752-636494
Auto Jap Spares
www.autojapspares.com/ 02476-474848
AutoLinkUK
www.autolinkmx5.com/ 01556-509088
SALES & SPARES;
Ian Taylor UK (Stoke on Trent)
www.japcarimport.co.uk/ 01782-594125
Southern Bongos (Southampton)
www.southernbongos.co.uk 02380-733995
Stephen McWhirter Services (Cumbria)
www.stephenmcwhirter.co.uk/ 07585-304362
Dore Service Station (Sheffield) doreservicestation.co.uk/ 0114-236-4691
Discount Trucks (Newbury)
www.disctrucks.f9.co.uk/ 01635-254185
Derwenthaugh Motors (Newcastle)
www.derwenthaughmotors.co.uk/ 07596-862711
Bongomaster (Leicester)
www.thebongomaster.co.uk/ 07873-314519
Doctor Bongo (Plymouth)
www.doctor-bongo.com/ 01752-224651
BREAKERS:
Milton Gough's Shaw Lane Carlton, Barnsley, United Kingdom. 01226 725356
www.facebook.com/Miltongoughs
Bongo Parts
www.bongo-parts.co.uk/ 01403-741913
Posted: Sat May 25, 2024 11:28 pm
by Sophiemay
Thanks so much, that's amazing help
