Fuse
turfite9999
Fuse
Post by turfite9999 » Wed Apr 26, 2023 9:49 am
Hi all Bongo going in for welding today and roof beeper wont stop does anyone know which fuse it is to temporary disable until I can fix please
Thanks in advance Tony
Re: Fuse
Post by g8dhe » Wed Apr 26, 2023 12:09 pm
There are two fuses one handles the power to the AFT motors and the other handles the power to lots of control modules as well as the AFT module see my fuse page http://www.g8dhe.net/bwm/ if you remove the fuse that covers the AFT Module you will also disable lots of other things which isn't what you want to do.
It sounds like the two travel limit switches at the top front of the AFT are not operating, the system needs both switches to operate before turning off the beeping, either the slider arms have not fully reached the front or one or both of the switches are out of adjustment see this diagram for adjustment http://www.g8dhe.net/bongo_images/aft/index.php?ind=0
