Radiator replacement
Posted: Sun Apr 23, 2023 4:03 pm
				Continuing from my previous post "LCA saved the day".
I have looked at the fact sheet and read as much as I can find about carrying out the radiator replacement and felt pretty confident to do this this so purchased a radiator and engine hoses. Probably overthinking the job now and have read about bolts breaking when removing the bottom cover. Does this happen frequently? Starting to get cold feet now as I have never removed a broken bolt before and don't have the necessary tools or knowledge. Any tips for carrying this out would be appreciated. (using plus gas or giving bolts a sharp tap). The hose clips are probably originals so may need replacing. I have read about the pros and cons of jubilee clips and would appreciate any comments about using them.
Could not have happened at a worse time as the master cylinder on the wifes car (Suzuki Alto) has failed, Suzuki has discontinued the part and no body has one.
