Random Screws
Posted: Thu Mar 30, 2023 12:53 pm
by Bongoplotter
A mechanic fitted a new TPS to my van yesterday and was puzzled as to the purpose of the two screws shown in the photos below.
Any ideas please? Thanks
- image1 (2).jpeg (21.6 KiB) Viewed 7468 times
- image0 (2).jpeg (22.16 KiB) Viewed 7468 times
Re: Random Screws
Posted: Thu Mar 30, 2023 2:21 pm
Not sure what screws your pointing at ?
Re: Random Screws
Posted: Thu Mar 30, 2023 2:48 pm
by Bongoplotter
- IMG_7329.PNG (95.87 KiB) Viewed 7452 times
- IMG_7330.PNG (100.52 KiB) Viewed 7452 times
Hopefully these zoomed-in versions help. Thanks
Re: Random Screws
Posted: Thu Mar 30, 2023 3:25 pm
The one behind the vacuum solenoid looks added or perhaps is holding the solenoid in place ?
The second one in the vacuum tubing is obviously blocking it because the tube is not connected!.
Have you tried the mechanical diagrams ? This link shows the entries for the vacuum system try each one in turn to find the pipe you have blocked and where it should go ?
https://www.lushprojects.com/bongoparts ... Ctr.html#6
Re: Random Screws
Posted: Thu Mar 30, 2023 6:09 pm
by Northern Bongolow
Geoff's correct, both screws are blocking the loss of vac or transfer to the next item in the pipework system maybe the solenoid has failed either open or closed, an applied 12 v supply to it will tell if the solenoid is operating.
Re: Random Screws
Posted: Thu Mar 30, 2023 8:46 pm
by Bongoplotter
Thanks very much both
