Charging advice
Posted: Sat Jan 14, 2023 12:13 pm
Hi all. Anybody is welcome to reply, but it is mostly aimed at my solar guru, Geoff!
Firstly a bit about my set up:
150w solar with MPPT controller
180ah sealed LB
Noco Genius 10a smart charger
VSR split charge relay (works both ways)
My question is:
If I am on EHU and have my smart charger on, topping up the LB as I'm using it. The split charge relay, due to working both ways, is also topping up my SB at the same time. Will my SB just keep charging regardless of it being full or not? Or will the smart charger and/or relay switch to stop adding power to SB when it's no longer needed. I have put an isolator switch between the LB and relay, so am able to isolate the SB if needed.
My starter battery does have a slight power drain, so it is useful to be able to top up on a few sources (alternator, solar, smart charger), but I don't want to risk overcharging.
Thanks in advance and sorry for the lengthy post!
180ah sealed LB
My question is:
