No dashboard lights/engine start - but other lights working.
Posted: Thu Mar 24, 2022 6:47 pm
A while ago, my Mothers' Bongo had its' MOT, at which time the garage charged up the battery (hadn't been used in a while).
Just recently I had the batteries out myself since again, it hadn't been started since the MOT and topped them up as she'd been thinking of going away on holiday.
About a week ago we kept hearing a car alarm going off, looking outside we never saw any indicators flashing so thought it wasn't us.
Few hours later it turned out to be us, the fob (cobra alarm) turned it off, turned it back on and everything seemed fine.
However yesterday we discovered that the alarm no longer works at all and we have to use the key in the door.
The interior light (above the windscreen) works when the doors are opened.
Once in, putting the key in the ignition starts up the reverse/AFT alarm (why is this, the roof is closed, no main lights etc. on and it was in Park? the door was open mind now I come to think about it), but no dashboard lights come on at all and turning the key does nothing.
I checked the fuse boxes (three under the bonnet, one down by the steering wheel, and the two in-line fuses of the alarm itself).
The fuses don't look blown, but all (interior and bonnet) of the PAL fuses are coated in verdegris.
The one fuse I didn't check was the Main 100amp, after finding it bolted in place, but presumably the interior lights wouldn't be working if it had blown?
We don't have any spare PAL fuses, so are any of them interchangable between bonnet and interior fuse boxes for testing if there's one we should try?
I figured I'd ask here in case it's something easy to troubleshoot (my worry is the alarm has failed and is immobilising the Bongo) before it gets booked in anywhere.
The alarm was never fitted by us, I haven't got the documentation to hand but think it's quite an old model.
