Injector pump seal
Posted: Tue Feb 01, 2022 11:02 am
Hello all.
I need to replace the seals on the advance plunger thingy on the injector pump as detailed in Dandys excellent thread. Using this thread and a number of others for little bits of info to help, I'm still none the wiser about the seal itself.
As per Dandys thread, on page 2, a user pointed out that an R20 washer has worked fine, but is this radius 20 and therefore 40mm dia? Is this i/d or o/d such as the difference between tube and pipe?
Not sure on the cross section, or if we know the Bosch part number for it?
Matt
Matt
