Revving in Park
Posted: Sun Jan 16, 2022 2:03 pm
by sotal
Just had a slight issue where whenever I put the bongo in P the revs would increase to about 1500-1800rpm.
Put it back in drive and it would drop below 1000 to what I would say was normal.
Is there any normal reason for this?
Related things I can thing of...
I've recently had to replace ATF fluid after a leak.
I've got an electrical fault in the drivers door hinge which is making the windows not work and send to be making a relay click randomly when going over bumps etc. (Relay sounds like it is near or in the drivers fusebox area)
Re: Revving in Park
Posted: Mon Jan 17, 2022 12:37 am
by teenmal
Sounds like the throttle mechanism is sticking , check the stop to make sure the cable is returning. Does the vehicle move off when drive is selected without using accelerator , what vehicle do you have ?
Re: Revving in Park
Posted: Mon Jan 17, 2022 7:03 pm
by sotal
Randomly it hasn't done it again since
It is the 2.5 diesel 4x4.
The revs do seem slightly higher at idle than I remembered, but around 900rpm now.
The other day moving it into park made the revs go up, then they would drop back when it was in park. You could repeat it, today nothing happens to the revs when you put it into park.
Re: Revving in Park
Posted: Tue Jan 18, 2022 8:39 pm
by sotal
Hmmmm, it did it again this morning but not tonight.
This morning as I got to my destination it seemed to be very eager to go. Putting it into park again raised the revs to around 1800 rpm. Putting it into drive dropped them down again but letting the brake off, it really wanted to go so I presume it was as if the throttle was partially down.
So possibly the throttle position sensor?
Is this something that can be helped with a bit of contact cleaner etc?
We've not used the bongo for a few months and it has had a few electrical gremlins since!
Re: Revving in Park
Posted: Tue Jan 18, 2022 9:49 pm
by teenmal
sotal wrote: Tue Jan 18, 2022 8:39 pm Hmmmm, it did it again this morning but not tonight.
Have you tried what I suggested, it sounds very much like a sticking acc cable or the pump mech.
Re: Revving in Park
Posted: Tue Jan 18, 2022 11:39 pm
by sotal
I'll have a proper look at the weekend, unfortunately it is dark when I'm driving it in the morning and dark when I'm driving back in the evening.
It does sound a good shout though, I'll check it out and update.
