2L petrol bongo won't start
Bongo_unchained
Post by Bongo_unchained » Tue Dec 28, 2021 4:38 pm
Hello, looking for a bit of advice with my bongo. It's been fine until out of nowhere it suddenly won't start as of a couple of days ago. I've checked battery (and recharged it after running it down!!), checked fuses, distributor looks OK. Took one spark plug out to check it was sparking OK and seems fine. Now thinking it must be fuel or compression issue, but wondered if there was an obvious thing to look for? I'm no mechanic but can find my way around an engine :D
Debs and David
Re: 2L petrol bongo won't start
Post by Debs and David » Wed Dec 29, 2021 12:21 pm
Hi first of all what year , Then do a search for 2l petrol not starting when cold hope this helps. Dave
Debs & David
You Need Degas to Make De Van Gogh
TheLongRoad
Post by TheLongRoad » Thu Dec 30, 2021 7:21 pm
Try starting it up in the dark, any HT lead / distributor issues are easier to see.
2002 Friendee 2.0 ltr Petrol.
