Advice for water tank.
Posted: Fri Oct 08, 2021 8:46 am
by Corden
Hello again!
Our bongo has a water tank and pump etc. I'm wondering how best to go about treating the system so the water can become drinkable. At the moment we dare not drink from it. Anything could be in there. At first I thought about throwing in some purification products and pumping through a couple of times etc.
Now I'm thinking twice about that. I sent a small rag down the water inlet pipe and when I pulled it back out again its had black marks all over it. Not gonna lie. A bit gross and definitely not suitable for drinking.
Do you think I can clean this any way? Pipe cleaners, purification tablets etc? Or do you think I need to be pulling the tank and pipes out for cleaning or replacements?
Thanks.
Re: Advice for water tank.
Posted: Fri Oct 08, 2021 9:16 am
by Bob
The camping shops sell cleaning products fo water systems, but I'm not sure how well they would work with the level of yuk you describe.
Maybe some of the fluid they clean beer lines with?
Posted: Fri Oct 08, 2021 7:03 pm
In normal frequent use then I run a purify rinse a couple of times a year. But given the amount of gunk, maybe be it would be worth replacing the whole system and start from a known clean state ? Then you will know the system is in a good state as opposed to worrying about it all the time!
Posted: Sat Oct 16, 2021 2:30 pm
by sotal
We were in the same situation, we just used bottled water (normally refilled from the tap) for drinking and to be honest used the bongo sink less and less as they years have gone by.
