Help - Starting issue
Posted: Thu Aug 12, 2021 8:17 pm
Evening all,
I recently got the bongo back on the road, and whilst on my way to take the dog out in it, just as I was pulling in to get some fuel she cut out. I thought the gauge must be out slightly and thought nothing more of it.
Filled her up, went to crank, nothing. Tried again, then she nearly sputtered into life but didn’t. Next couple cranks the starter motor started giving it the machine gun effect. I called recovery, and he tried his boost pack, on some turns of the key the starter would do nothing, on others it would half crank like it was powered by a dead battery, even with his power pack.
Eventually I got dropped off home after piggybacking the breakdown truck. Tried it again on the drive and still acting like a flat battery and knackered starter.
Changed the starter, charged the battery and it was still a sluggish half turn of the engine and then nothing. So I bought a new battery thinking I’ve killed that one...fitted it, and ....still the same.
I’ve checked the engine earth strap, the motor is connected and everything seems to be tight & as it should be. I wait for the glow plug light to go off too, but it just doesn’t want to or have enough balls to crank. I’ve even turned the engine by the flywheel just in case it had mysteriously seized but that’s fine.
Am I missing something completely obvious here?
Also, not sure if it’s somehow related, but my central locking didn’t lock all the doors on that day before I headed out either, I had to unlock & lock a couple times before they all locked together, but it never used to do that.
Any pointers are appreciated!
