Leak..... I think!!?
Posted: Thu Aug 05, 2021 10:10 am
by Bongotrio
Hi guys, first post here hope you can help. Went to look at our first bongo the other day, liked it and want it, perfect for us..... BUT... when looking at it, it had some water under the front middle, about 2/3 feet under (not quite under engin) a few drips dripped while i was looking at the the wet patch, started her up and nothing, water looked clear and scent less, coolant in tank fine. It's a 2l. Looked under and above (from bonnet) couldn't see anything. Any ideas?? Cheers.
Re: Leak..... I think!!?
Posted: Thu Aug 05, 2021 10:13 am
If the Air Con had been running then it will have just been condensation from the cooling matrix, given that it was likely to have been a hot humid day!
Common concern, also can appear at the rear cooling matrix behind the drivers seat, just make sure that it isn't a leak from the heating circuit however
Posted: Thu Aug 05, 2021 10:30 am
by Bob
Good info from Geoff, and the 2 ltr is the simplest, self bleeding so not the world if a hose should need replacing.
Posted: Thu Aug 05, 2021 10:43 am
by Bongotrio
Ah thanks Geoff , the a/c was running! We had engine running pretty much whole time as checking out the aft and stuff.
