2L petrol (2000) wont start when cold
Posted: Sat Jul 10, 2021 9:43 am
Hi all
We have had our bongo for about five years without any problems. Until now ...
A couple of months ago the engine died about a mile from home for no apparent reason and refused to restart. So I called the breakdown people who arrived about an hour later. The mechanic had a quick look under the bonnet and then asked me to try starting the bongo. It fired first time and was fine for the rest of day.
Since then it has become increasingly difficult to start the bongo but the symptoms are always the same. The issue arises if the air is damp and only when the bongo has been stood overnight. I can hear the engine turning over but does not fire. Repeated attempts to start either results in success or a flat battery. If it does start it runs as expected and I can stop and restart without any issue for the rest of the day.
So I changed the obvious ... spark plugs - HT leads - rotator arm and distributer cap. Its was time they were changed anyway. This did not resolve the problem.
Now our bongo was due a new timing belt so I got the necessary parts and booked the bongo in. When I dropped of the bongo of I told the mechanic about the starting issue in the hope they could sort it. However the following morning was bright and sunny and so the starting issue didn't occur.
I've had a good read around but seem to be going around in circles hence this post. Has anyone any suggestions as to where to look next?
Any help or thoughts on the matter would be much appreciated
Pete
Pete
