Bongo Friendee - Headlight not working
bongoju
Post by bongoju » Sat Feb 27, 2021 10:44 pm
Hi, a little help please ;?;
Mazda Bongo Friendee 2.5V Petrol 2002
Far side HID headlight stopped working, - 12v supply to HID ballast not present- cable dead.
Supply to Nearside headlight HID ballast okay and the relay on the inside of the passenger side wing under the bonnet operating okay.
Question: Is there a separate relay for the far side headlight and where it is positioned?
Thanks for you help!
Re: Bongo Friendee - Headlight not working
Post by Bob » Sun Feb 28, 2021 2:04 pm
Not sure what the problem is, but welcome to the forum. 8)
Hopefully our electrical wizard will be along. :wink:
Post by Doone » Sun Feb 28, 2021 2:18 pm
Not a seperate relay but there are seperate fuses for each headlight, located in the fuse box in the drivers footwell.
Post by Ian » Sun Feb 28, 2021 2:26 pm
Doone wrote: Sun Feb 28, 2021 2:18 pm Not a seperate relay but there are seperate fuses for each headlight, located in the fuse box in the drivers footwell.
That's true for earlier models. But on later (02) petrol Bongos there is a fuse under the bonnet, rear bank of 4, second from the left. 30 amp, but 40 amp if you have Xenons.
bongoju
Post by bongoju » Sun Mar 14, 2021 8:49 pm
Hi Ian and Doone
Apologies for the delay in replaying. The Bongo is not kept at home and due to the lockdown I was only able to travel to the place yesterday.
I am aware of the 40amp main fuse but that cannot be cos one of there is power to onne of the headlights/
Doone was spot on. I located the fuse box in the drivers footwell and noticed the 20amp fuse for the right headlight is missing!!!! How could that have happened I simply don't know.
Anyway, fitted a new fuse and the headlight is back on.
Many thanks for your help.
My next adventurer is going to replace the engine oil and filter! All the best.
bongoju
Post by bongoju » Sun Mar 14, 2021 8:52 pm
Sorry for the typos. Nead to review before sending :D :D
Post by Bob » Sun Mar 14, 2021 9:10 pm
No worries. :wink:
Feedback is always really useful. 8)
Post by Doone » Mon Mar 15, 2021 9:12 am
It's good to hear its all sorted. =D>
